Peters Web Site
CH650B
6-T-1C pg 3 - 5
Drilled Ribs to Rear Spar and made 4 L - Angles
Calmped the rear Spar to the ribs (one at a time)
Drilled and cleco'd each rib to the rear spar.
Cut 4 75mm L angles out of the 4 ft L angle length. Rounded the corners with a flat file.
CH650B Home
101
