Steves RV-7 Web Site
Date:  1-1-2015
Manual Reference:  Section 6 REAR SPA
Brief Description:  Day 1. Begin work on HS-609PP
Well the day has finally come where I officially started working on the RV-7. I have not finished working on the practice kit but I thought the date of 1/1/15 would be a great way to start the New Year. It also makes it easy to remember when I began.
The first task is to break the edges of HS-609 PP so that they fit inside HS-603PP flat against the surface. I think using a file will keep the edge more consistent compared to a scotchbrite wheel. I will finish it up on the wheel to make that smooth shiny surface.
Breaking the edge with file
More filing
More filing
Used 150 grit with sander to clean up surface
