I wanted a better way to drain the compressor at night so Tyler and I went to Lowe's and got some fittings and a ball valve. The stock drain valve was hard to get to and you really should not try to open it until the air pressure is below 40 psi.
With the new valve I can just crack it open and walk away. If the noise becomes an issue, I will just pipe it to the outside.
