Brief Description: Dimpled the Vertical Stabilizer
Took about a week off from actual work on the airplane but have been doing alot of research on different aspects of the build.
Took some time today to take the HS apart and get some dimpling done. The rear spar reinforcement bar has to be machine countersunk based on the call out on the plans. This is the side of the spar that will mount flush to the fusalage.
