Brief Description: Started on the Vertical Stabilizer
The VS-410PP hinge brackets have two holes missing from the pattern so I had to match drill the upper bracket. The bottom brackets holes will be drilled when attaching to the fusalage.
Now it's back to edge finishing flange straightening/fluting and deburring.
