Today Matt and I made a mounting arrangement for the DRDT-2. The tool comes with plans to make a small table that give you some support on each side. I thought it would be better to have more room for larger skins. The way it is built allows me to adjust the position in and out if needed. I can slide the tool and box out significantly and clamp the box to the 2x4 rails. We also made some table connectors in the front and back to keep the tables together. This will help prevent accidently pulling the tabels apart and dropping the DRDT-2.
