Brief Description: Rivet HS Spar and prepared skins
Riveted both HS609pp stiffeners to the HS603pp rear spars. The manual was right, setting -4 rivets with a hand squeezer is quite hard. I also deburred the edges of the skins and wiped them down with a 3M pad in preperation for priming.
