Brief Description: Finished deburring skins and ribs on HS
Finished deburring skins and ribs on HS. After nearly finishing I found that I was not pleased with the quality of the deburring. I have been using the tip from an ATS speed deburring tool inserted into a cordless screwdriver. While this seemed to work alright at first I found that the tool doesn't seem to work nearly as well on the 3/32 holes on the skins. I therefore thought I would try a drill bit in the cordless drill and I have been happy with the result.
The ATS speed deburr tool and the cordless screwdriver
A close-up of the tip, just a 100 deg countersink bit.
