CAF Carl's Aircraft Factory
Date:  4-16-2006
Number of Hours:  2.50
Brief Description:  Began riveting VS
Retrieved the parts from the paint booth and began riveting the vertical stabilizer. The first step was to rivet the 808 doubler to the 803 spar channel, using flush rivets on the lower half. This also included installing the steel rudder mounting brackets. Once that was completed I riveted the internal skeleton together and then clecoed the skin to that. Then I had just begun riveting the skin when the smell of turkey drew me away.
Rivet detail on VS808 and 803
