PIERRE'S WEB SITE
HELICYCLE
Torqued controls
Forward cyclic bolt 5/16 torqued at 120 in/pd + loctite
torqued bolt 65in/pd + loctite PN 13-303 cyclic proof command (AN4)
greased the cyclic collective slider in the zerk Marine SL 3120
Dive Shaft Tail Rotor cleaned inside + Corrosion X
Torqued the shaft bolts at 36in/pd + torqued seal
Slider cyclic shaft 2 side bolts 5/16 torqued 100in/pd + Loctite + safety wire
HELICYCLE Home
463
cabin
ELECTRICAL
Frame
Instrument Pannel
Main Rotor Blades
Main Rotor Hub
Main Trans
solo flight
Tail rotor
transport
Trim Fins
weight and balance
