Patricks Web Site
Date:  12-10-2006
Number of Hours:  4.90
Brief Description:  Redo L rib and Inner Attach Angles
Found I mis-drilled the L inner leading edge rib and attach strip. Correction put holes too close together. Ordered new, edge finished and straightened piece, re-fit and re-drilled. Also found mis-fit outer tank attach angles. Ordered new, re-fabricated and re-installed.
