Brief Description: Completed fabrication of trim tab hinge
Replaced Elevator side of E-721 trim tab hinge. With the replacement of the tabs outboard of the trim tab, the trim tab assy needed to move outboard 1/16" to match. This required replacing Elevator side hinge. Drilled and dimpled hinge.
