Worked on the parking brake valve plumbing and actuator cable anchor. Fabricated braided stainless steel lines from the master cylinders to the parking brake. Fabricated an anchor for the actuator cable. Worked on fabricating the flex lines for the master cylinders but was not happy with the stiffness of the 1/4 inch nylon lines. decided to do what I die on my S19 and am going to 1/8 lines per Matco. Ordered the fittings and line from Matco.
