Phils Web Site
Date:  3-24-2020
Number of Hours:  5.00
Brief Description:  Misc.
Rermoved th engine from the firewall. Installed a stainless steel patch where we impeoperly cut the hole for the heat valve. Installed the heater valve to the firewall. Located and drilled a hole in the firewall for the throttle cable to pass through. Reinstalled the engine to the firewall and torqued the mounting bolts from the mount to the fuselage.
