Frustrating day. Difficulty in riveting the top forward gussets with bad "smiles" in some rivets drilled out a couple and have a few more to replace. Also dropped a bucking bar and dented the bottom skin. Will need a little body work before paint, at least it is on the bottom. Riveted all the canopy rails around the cockpit. Also began fitting the aft top skins.
