Fit, dimpled, primed, installed and riveted the aileron and flap gap seals. Prepped and primed the lower wing skins and clecoed to the frame. Readt to rivet the lower skins. Began assembling the FlyLed wing tip lights. Got the two circuit boards with the strobes and position lights for the left wing. Tested using a nine volt battery so they are not full intensity. Still need to assemble the landing lights and the right side lights.
