Brief Description: Spinner and fuel return and pressure sender lines
Drilled the mounting holes for the spinner to the backing plate. Mounted the nut plates. Finished trimming around the prop blades. Fabricated the fuel line to the fuel pressure sender. Measured and ordered the fuel return line.
