Phils Web Site
Date:  8-26-2014
Brief Description:  Coolany
Installed coolant and discovered a number of leaks. I had used Oetiker clamps as I have had good results with them in the past. Not sure if it is a combination of the type of hose and the metric fitting. Replaced the clamps on the 1" hose with standard screw type clamps and so far no leaks. I am borrowing a presure tester to check the connections under pressure.
