Phils Web Site
S-19
Mounted engine
Mounted the engine to the motor mount. Had to add three thin S.S. washers between the engine and motor mount at the right foward and left rear bolts in order to obtain the correct thrust offset. Began laying out routing for the plumbing and wiring.
RV9 Home
S-19 Home
2070
Ailerons/Flaps
Final assembly
Firewall forward
Fuel system
Fuselage center
Fuselage forward
Fuselage rear
390
