Due to open heart surgery I have not been able to work on the project. As I am currently restricted to lifting no more than 10 pounds I am unable to do any real work. I figure I might as well use the time to at least install the new carb floats as required by Rotax Service Bulletin SB-912-067UL. Went to the airport and removed the carbs and replaced the floats.
