Phils Web Site
S-19
Firewall forward
8-20-2014
Scat hoses
Worked on the cabib heat, carb heat and air filter scat hoses. Tight fit. Had to rotate the cabin heat muff so the outlet is pointing down and forward to allow more room to fit the hoses to the air box.
RV9 Home
S-19 Home
2070
Ailerons/Flaps
Final assembly
Firewall forward
Fuel system
Fuselage center
Fuselage forward
Fuselage rear
390
