Phils Web Site
S-19
Firewall forward
7-14-2014
Cowling
Cut out the openings in the lower cowl. Need to open the lower radiator/oil cooler opening a bit more. Fitted the upper cowling, attached with 3/32 clecos. Drilled some of the holes to #11. A lot of fitting and trimming!
RV9 Home
S-19 Home
2070
Ailerons/Flaps
Final assembly
Firewall forward
Fuel system
Fuselage center
Fuselage forward
Fuselage rear
390
