Finished installing the trim pushrod and attached the tailcone. The rudder pedals were not aligned. Adjusted the rudder return springs and rudder cables at the pedals. Also replaced the nuts on the motor mount to fuselage with the proper all metal stop nuts. A real pain getting to things under the panel. Very happy we installed the inspection holes in the forward fuselage sides.
