Phils Web Site
S-19
VS front spar
Started the assembly of the VS with the front spar. Discovered that a rib stiffener was mis-marked and I have two spar stiffeners. Called Rans and they are sending a new part. Also poured the lead for the stabilator counter weight.
VS front spar initial fitting
RV9 Home
S-19 Home
2070
Ailerons/Flaps
Final assembly
Firewall forward
Fuel system
Fuselage center
Fuselage forward
Fuselage rear
390
