Attached rib 1. Alignment issues when attaching rib; as such, I had to re-drill a couple of holes. Hopefully, the rivet will attach properly. Also, I am concerned about overall alignment and twisting of rudder. How do you ensure that the rudder does not twist or mis-align when the holes are not pre-drilled? Need to call Zenith.
