When I installed the "Wing Lower Root Skin" ( a couple of years ago ), it was on the first wing I built. I did not realise it was incorrectly cut, I should have realised it was wrong, it is quite obvious. The two cutouts for the rear spar attachment point and landing gear leg were not correct.( photo one ) It was a simple fix using the dremel and being careful.
