Peters Web Site
Date:  2-25-2023
Number of Hours:  4.00
Brief Description:  Cabin Heater.
Today I worked on connecting the cabin heater control cable.
It's not the best system for the heater control using such a stiff cable.
I have tried to figure out a better system but failed.
There are hundreds of Sling4 flying around in the world using this system, so it must work OK.
I shortened the cable and installed the " Cable Adjuster "
I have routed the bowden cable behind the instrument panel with sweeping turns.
The cable passes through the firewall on an angle passing through a rubber grommet.
I will tape around the grommet on the engine side to minimise any leaks.
The heater controller seems to work quite well, with a reasonably smooth motion and not too stiff.
Cable adjuster lock wired.
Heat-Shrink installed.
Cable connected to heater box.
