Peters Web Site
Date:  6-23-2022
Brief Description:  Airbox and Drip Tray.
I started working on the drainage pipelines to the airbox and drip tray.
The factory use clear plastic 6mm tubing which obviously works, however I decided to use 6mm silicone hose.
The drainage hoses are close to heat sources so the silicone hoses will be more heat resistant.
I purchased some constant tension spring clamps to connect the hose to drip tray and airbox.
I was going to use the clamps on the " T " connections, but they would be a scratch hazard, so I safety wired the connections.
Left side drainage hose.
Airbox connection.
Airbox connection.
Drip tray connection.
