Peters Web Site
Date:  5-16-2022
Number of Hours:  3.00
Brief Description:  Engine Cowls.
I drilled the 9.52mm ( 3/8" ) holes for the Dzus fastener collars on the top cowl.
I also drilled the 8mm holes for the Dzus fasteners and the 3.2mm holes for the retaining springs on the bottom cowl join.
The cowls are nearly ready for painting, just a little more filling of scratches and rough areas.
I covered the radiator support bracket bases which do not require painting.
9.52mm holes for Dzus collars.
Radiator brackets covered.
Top engine cowl.
Top engine cowl.
