Peters Web Site
Date:  4-15-2022
Number of Hours:  1.00
Brief Description:  Mounting The Radiators.
I finished installing the last of the radiator levers.
The final mount is very difficult to access and I wanted to install 4mm washers on the rivet tails so I was not pulling on the fibreglass.
I decided to drill a 12mm hole beside the lever which allows me to access the 5mm screw and some chance of installing the 4mm washers.
After a few very tricky moments ( and colorful language) I managed to get the washers installed.
With the aid of a dental mirror and an inspection camera I was able to confirm all rivets and washers are set OK.
I have installed a blanking grommet in the 12mm hole, now painting is required.
12mm hole.
12mm hole.
Rivets with washers installed.
Blanking grommet.
Blanking grommet.
