Peters Web Site
Date:  4-8-2022
Brief Description:  GPS Mount.
The mount for the G3X and GPS 20A antenna's makes it difficult to work on the wiring behind the engine.
The factory rivets this mount to the firewall.
I decided it makes more sense to have it rivnuted so it is easily removed for better access behind the engine when working on the wiring.
I opened up the holes in the mount and firewall to install 4mm rivnuts, which are more user friendly.
4mm rivnuts installed.
GPS mount with 4mm screws.
Much better access.
Much better access.
