I made a bracket for the" Throttle Positioning Sensor Plug ". ( aka TPSP ). The bracket and TPSP are mounted on the upper left hand engine mount with 18mm P-Clips. The bracket is lined with a self adhesive rubber backed lining. I will source a dust cover for the 9 pin D-Sub plug, definitely will not fall off.
