Worked on the oil system hoses and connections. Connected the turbo overflow hose to the banjo and re-torqued the connection. I had to replace the hose from the thermostat to the oil pump because I cut the hose too short, well, only one end was too short. ( that took quite some time ). Once hose was replaced I connected it to the oil pump. I also made a new bracket for the turbo oil overflow oil hose.
