Peters Web Site
Date:  4-5-2024
Number of Hours:  4.00
Brief Description:  Wheel Spats.
Back to my wheel spat problem this morning.
After a lot of head scratching, thinking, checking other builders blogs and finally consulting the build manual, I identified the issue.
The four holes in the "Main Spat Cover Composite " ( the position was marked by TAF in manufacture) were out by approximately 5 mm.
I have re-drilled the holes which are used to attach the " MSCC " to the Main Wheel Spat Bracket.
Now the spats fits correctly and are not under any pressure or force.
I will fill the original holes and get the MSCC repainted, which is not a big job.
MSCC holes re-drilled.
