I have been doing a number of small fiddly jobs on the aircraft this week. I shortened the wiring loom to the ELT, which was far too long. I'm still waiting for the 15 pin D-Sub plug to arrive in the post. I was at Richards, the painter, and noticed he had painted the inside of the cowls. We were only going to prime the inside of the cowls, however Richard has also painted the inside with a white top coat. Not an issue in anyway, the inside of the cowl will be more resilient to oil and dirt. I bought the top and bottom cowls home to install the Dsuz fastern springs prior the the final outer top coat of paint so the countersunk rivet heads will be painted.
