Peters Web Site
Date:  6-7-2022
Number of Hours:  1.00
Brief Description:  Lock Pin Plug Bolt.
My engine did not have a place to safety wire the magnetic plug.
I have photos from the factory which show that the safety wire from the magnetic plug is secured to the " Lock Pin Plug Bolt " ( LPPB ), mine does not have a hole.
I removed the " LPPB " and drilled a hole for a safety wire to secure the magnetic plug and re-torqued the bolt to 15 Nm.
LPPB removed.
LPPB removed.
LPPB drilled.
LPPB drilled.
LPPB reinstalled, torqued to15Nm.
