Peters Web Site
Date:  9-12-2021
Number of Hours:  4.00
Brief Description:  Fuel and Manifold Pressure Sensors.
Put my soldering skills to the test today and attached 16AWG extension wires to the two pressure sensors.
After the FT- 60 fuel flow sensor is installed, I will run and trim the wires to fit
" Engine Plug #1 ".
I temporarily connected the extended wires to the plug and everything indicates correctly.
The QNH here today is 1005 mbs ( 29.68" ) and here at home we are about 2200 - 2300 feet AMSL.
( I should have set 1005 on the altimeter for the photos ).
As we know, approx.1 inch hg change per 1000' therefore 29.68" minus 2.2 - 2.3", manifold pressure should indicate approx. 27.48 - 27.38", so 27.4" is correct.
Wiring extended
Wiring extended
Ready for installation.
Gauges indicating correctly.
