I continued securing wiring, which is taking quite some time. I noticed that later engines have heat shield on the bottom of the drip tray. I had some heat shield let over after applying it to the fuel pump cover. I decided to install heat shield to the drip trays. This will help reduce the heat transfer to the float chambers on the carburetors.
