Brief Description: Brake Lines and Throttle cable.
Managed to find some enthusiasm to do some work in the build shed. I installed straight brake line connectors and after I installed them I decided a 45 degree connector on one end would be much better. ( only have one 45 degree. ) The 45 degree connectors have been ordered, should be here in a day or two. I also installed the throttle cables and have discovered they are short. The packing list says the outer cable should be 1220mm, mine are 1150mm. I think I may have a set of Sling 2 throttle cables not Sling4. ( Bugger.) The Australian Sling agent will see if he has a set of 1220mm cables, if not, an e-mail to JNB.
