Peters Web Site
Date:  3-19-2021
Brief Description:  Stainless Steel Cable Ties.
I have decided to use S/S cable ties on the fire sleeves instead of lock wire.
The stainless steel cable tie tool was delivered yesterday.
The cable tie tool is easy to use and cuts the end of the tie without leaving a sharp edge, which is very important.
The tool has adjustable tension settings and I have experimented with different settings and decided I need a lower tension setting.
S/S cable tie tool.
S/S cable tie tool.
Fire sleeve, ties and tool.
S/S ties on fire sleeve.
