Peters Web Site
Date:  3-27-2022
Brief Description:  FT-60 Fuel Flow Sensor.
This week I'm going to try to organise someone to silver solder the 6mm barb fittings in the fuel supply line to the right hand carburettor.
I purchased some S/S 6mm barb fittings recently with the thought of silver soldering stainless steel fitting to a stainless steel pipe.
I have cut the fittings in half and will decide which half to use when I discuss it with the soldering person.
6mm S/S double barb fittings.
Fittings cut in half.
Not sure which half will be used.
