Peters Web Site
Date:  10-25-2017
Brief Description:  Undercarriage
Installed the undercarriage today.
I was not looking forward to this job because other builders have had troubles.
My undercarriage went on without too many issues.
I did three things which helped with the installation.
1. I grounded the bolts slightly to more of a point.
2. I lubricated the bolts.
3. I made a small 10 mm pin which I tapped into the hole on the opposite side of the bolt which kept everything in alignment.
When I tapped the bolt through it pushed the pin out.
Two of the four bolts I had to screw through the last little bit as it exited the other side, the other two tapped through.
There is no info. from what I can see in the manuals re: torque setting for the bolts.
A quick e-mail to the factory and Vince replied torque the bolts to 24 nm.
Torqued to 24nm.
Torqued to 24nm.
Bolts slightly pointed.
All done.
All done.
