Peters Web Site
Date:  2-5-2020
Brief Description:  Engine Mounting Bolts
Shortened the engine mounting bolts.
I cut an aluminium tube to 122mm and slipped it over the M10 bolt to have exactly the same length on all bolts.
It worked very well using a dremel to shorten each 130mm bolt to 122mm.
122mm tube and bolt.
Cut 8mm off the 130mm bolt.
All exactly the same length.
