Peters Web Site
Sling4
Engine Mounting Bolts
Shortened the engine mounting bolts.
I cut an aluminium tube to 122mm and slipped it over the M10 bolt to have exactly the same length on all bolts.
It worked very well using a dremel to shorten each 130mm bolt to 122mm.
122mm tube and bolt.
Cut 8mm off the 130mm bolt.
All exactly the same length.
Sling4 Home
2955
353
475
Firewall
Flight Controls
Flight Controls.
41
89
Front Windscreen
66
Fuel Tanks
25
66
447
81
87
Propeller
49
87
Propeller
Undercarriage
25
66
Undercarriage
41
89
Upholstery
Upholstery
Windscreen
198
