Peters Web Site
Date:  5-15-2019
Brief Description:  Front Top Rib.
I made eight stringers to go between the firewall and the front top rib.
I drilled the holes in the firewall mounting channel, four each side, with the aid of a jig I made.
I may not need all of the stringers ( GTX35R is to be riveted to the bottom of the front top rib, right hand side ) so I will cleco them into position for the time being.
If I do require the stringers in the future it will be easy to rivet them into position to support the electrical wiring.
Stringers.
Stringers.
Three cable tie points riveted.
Drilling jig.
Drilling jig.
