The factory supplied two covers for the Gear bolt inspection ports on the rear floor. The covers would cover a number of rivet heads on the rear floor so it would not sit flat. I know the cover would be under carpet, however I decided to make my own covers. My covers are attached by two 3mm screws into rivetnuts which I will be able to remove for routine inspections. The inside trim panels just allow me to access the screws.
