Peters Web Site
Date:  10-27-2017
Number of Hours:  3.00
Brief Description:  Inside Front Skin.
I was talking to BDH yesterday and he was saying how the inside side skins needed to be installed early in the build on the taildragger.
I came home and checked the Sling4 inside side skins, which can be installed later in build.
I have noticed at the factory they install the front inside skin early during the build.
I started installing the inside skins and the left skin would not fit on the front side channel.
The right skin fitted very well, so I matched them and found the left skins side channel holes have been punched incorrectly. ( all misaligned along the channel by about 4mm )
This skin is covered by the interior upholstery and will not be seen, so I match drilled the holes.
The only thing I did not think about is the wing bolts.
I will have to cut the rear lower flange to allow the bolts to be fitted into the main spar.
I will cut the right skin prior to installation.
Ready for side skin.
Misligned holes.
Misligned holes.
Inside side skin installed.
