Peters Web Site
Date:  3-9-2017
Number of Hours:  3.00
Brief Description:  Sanding Rivets.
After talking to SK in Ballarat, I purchased a mini sander, to sand the rivet heads.
I drilled a hole in a strip of aluminium to protect the skin from the sanding head.
It worked very well, completed one side in about two hours, thanks to JAC.
This process is very fast and does a good job.
4mm rivet with shroud.
Mini 2
Mini 2" orbital sander.
JAC hard at work.
JAC hard at work.
