Peters Web Site
Date:  9-11-2023
Brief Description:  Left Fuel Quantity Sender.
I wanted to ensure the fuel quantity sender was working before the wing is installed
If I had a problem it is so much easier addressing the issue with the wing off the aircraft.
I attached a wire from the fuel quantity sender to the left wing electrical plug.
I changed the fuel volume units to U.S gallons, as I had the figures from Rod's build, which are in US gallons.
I put two calibration points in the configuration fuel calibration page and the left fuel gauge indicated one gallon.
So, the fuel level sender does work.
I then removed the two calibration points and returned the fuel volume units back to litres.
Wire attached to fuel sender.
Fuel calibration page.
Left fuel gauge indicating 1 gallon.
