Peters Web Site
Date:  8-30-2023
Number of Hours:  4.00
Brief Description:  Landing Lights.
The landing light support brackets I was supplied with were for incandescent lights.
I had to modify the brackets for the PAR36 LED Taxi and Landing lights.
Both the front and rear brackets had to be enlarged slightly to accommodate the lights.
I was not sure how I was going to be able to enlarge the hole by just a couple of millimetres
I came up with the idea of clecoing the front brackets together and the rear brackets together.
I purchased a " Flap Wheel " and put it in the drill press which allowed me to modify the four brackets at the same time.
I wanted a sanding drum, but the hardware store was " out of stock".
I moved the brackets around in a circular motion, supported by the clecos and the flap wheel did the rest.
This method worked really well and the eight brackets are now all modified.
I have painted the eight brackets with an aerosol full gloss white paint.
Flap wheel in drill press.
This worked very well.
One side painted.
One side painted.
